Location: PORT ALLEN, LA. NEXT DOOR TO STATE CAPITOL RACEWAY
Anyone know how to read the date code ? I called the south central distributor, they couldn't tell me and gave me a ph. Number to a engineer and am waiting for him to call me back. The code is "5ZVH"
Liked 100 Times in 45 Posts
I might be wrong but on DOT tires the date code is four numbers,as in, 2810,which would be the 28th week of 2010.Check on both sides of the tire and see if you find one with four numbers.If not then in the immortal words of Emily Latella "never mind".
Former NHRA #1945 Former IHRA #1945 T/SA |
It appears that gy has changed from old system, ie the "2810" as you stated. There is no other four digit codes on either side.
Liked 332 Times in 180 Posts
you will need to know the D code number on the tire, the size, and that number letter code when you talk to Gyear---they no longer use a date code like years past---the new way of coding tires has the "code" you found and will tell you the number of tires produced in that batch,the date of manufacture, construction and compound characteristics of that batch of tires etc---YOU CAN NO LONGER TELL THE PRODUCTION DATE OF A G'YEAR RACE TIRE by a date code as in years past they went away from that more than 2 years ago---make sure you have that info handy when you talk to the Gyear race tire guy---that is the only way to tell any dates etc
#5 | |
Call Competion west in Michigan their guys "seem" to be a little more knowledgeable when it comes to the "sportsman" tires--not saying that your guy is not but its worth a call- FED387
