Liked 10 Times in 10 Posts
A class that could have been created by the NHRA in 1965,,,,
For 1965 production cars only,,,,,,, permitting the dealer to install a big-body car engine in the intermediate car which could fit in the engine compartment without modifications,,,,,,,,, Class; BB/S or BB/SA Using a car base weight of approximately 3400 to 3500 lbs, and a general horsepower rating of 375 HP With a Weight-to-Horsepower factor around 9.00 1965 Cars Classed for BB/S or BB/SA Oldsmobile 4-4-2,,,,(with the 425/370 HP Starfire-Engine Option) * 370 HP @ 4800 RPM,,,,,,,,470 Ft.-Lbs. of Torque * Compression Ratio = 10.50 - 1 * Camshaft = .472/.461 lift,,, w/ 286*/280* duration and 50* overlap * High-rate valve springs w/damper * Late-year production cylinder heads (#389335) w/larger intake ports and 75 cc combustion chambers * Smaller 75 cc heads (standard heads 77 cc) increased compression to 10.7 - 1 * Special larger intake valves 2.067" * Standard size exhaust valves 1.63" * Cast iron medium-riser dual-plane intake manifold * Quadrajet Spread-bore carburetor 750 CFM (Late-production 1965 model #7025151) * Special dual-point distributor Note: The 425 'Starfire' engine featured larger lifter bore sizes, to handle camshafts with a more aggressive profile. Buick GS,,,,(with the 425/380 HP 'Super Wildcat', 'Y48' Option) * 380 HP @ 4800 RPM,,,,,,465 Ft.-Lbs. of Torque * Compression Ratio = 10.25 - 1 * Camshaft = .439/.441 lift,,, w/ 290*/299* duration and 77* overlap * High-rate dual valve springs * Medium size port heads with 1.87" Intake / 1.50" Exhaust * Buick Experimental aluminum medium-riser dual-quad intake manifold * Twin Carter AFB's 625 CFM (1 9/16" x 1 11/16") * Special dual-point distributor Note: The standard 401/325 HP 'Nailhead Engine' in the 65' Buick GS (B/Stock Class) gets replaced with 'Super Wildcat' engine, with the 'Y48' option. Note: Featuring, a 'medium-lift' camshaft, but with a long duration. High-rate dual valve springs, to eliminate valve float at higher RPM's. And, the 'experimental' aluminum dual-quad intake manifold, with twin gas-guzzling/air-sucking Carter AFB (625 CFM) carburetors. Note: This 425/380 HP engine combination (found in the 1965 Buick Wildcat) put out 55 more horsepower than the 401/325 HP engine (found in the 65' 'high-performance' Buick GS) Pontiac GTO,,,,(with the 421/376 HP 'HO', 'YK' Code) * 376 HP @ 5000 RPM,,,, 461 Ft.-Lbs. of Torque * Compression ratio = 10.75 - 1 * Camshaft = .417/.419 lift,,, w/ 288*/302* duration and 63* overlap * High-rate dual valve springs * Medium size port heads with 1.92" Intake / 1.66" Exhaust * Tri-carbed cast iron intake manifold * Triple Rochester carburetors * Special dual-point distributor Note: The camshaft was the famous 'HO' '068' bumpstick, with a moderate lift, but radical duration. Note: The 421/376 HP 'HO' Rochester Carburetor ratings;,,,, Center-Carb = 278 CFM,,,,,, Front and Rear Carbs = 308 CFM Note: The 65' engine featured a new-revised high-riser intake manifold. Last edited by Paul Ceasrine; 12-24-2011 at 05:40 PM. |
Pete,
1965 A/Stock = 8.70 to 9.49 Wt./Hp...........(Would have been changed to 8.30 to 8.89 Wt/Hp) The A/Stock cars in 1965 were running; A/S = 12.70's A/SA = 12.95's 1965 B/Stock = 9.50 to 10.59 Wt./Hp. factor.....(Would have been changed to 9.50 to 10.09 Wt/Hp) Also known as, the 'factory' general street-musclecar class The B/Stock cars in 1965, were running; B/S = 13.00's B/SA = 13.30's The 1965 proposal would have had the BB/Stock cars (1965 only cars) with a 8.90 to 9.49 Wt./Hp. factor,,,, A 'dealer prepared' street musclecar, with a big-body car stock performance engine,,,, Which would have put the; 1965 Buick GS,,,,,,,,,,,,,,, 425/380 HP,,,,,,(3430 lbs.),,,,,,,9.03 Wt/Hp 1965 Oldsmoblie 4-4-2,,,425/370 HP,,,,,(3395 lbs.),,,,,,,,9.25 Wt/Hp 1965 Pontiac GTO,,,,,,,,,,421/376 HP,,,,,,(3467 lbs.),,,,,,,9.25 Wt/Hp All within a great competitive class,,,,with cubic inches, horsepower and weight pretty much equal.... 1965 Elapsed Times,,,,,,,, probably in the 12.85 range,,,, Last edited by Paul Ceasrine; 12-28-2011 at 08:09 AM. |
Liked 12 Times in 12 Posts
Here's a 65 Olds 442 two door hardtop, it's not a bad looking car.
To bad Chrysler didn't have any Street Hemi's in '65...they just had Race Hemi's.
Or how about a big-block 65 Chevy Nova perhaps.
Liked 53 Times in 25 Posts
Dennis P Chapman 1904 STK NHRA National Record Holder Car Owner. |
Liked 5 Times in 5 Posts
Mopar for 1965 in BB/S,,,,,,,,,,
The 426/385 HP "Nascar Race Wedge' from 1964 would have worked,,, Single-carbed, with the 'special' Holley 835 CFM carburetor.. pc Last edited by Paul Ceasrine; 12-28-2011 at 10:05 PM. |
