Old 11-02-2011, 11:21 PM   #1
COPPERN
Default 60 ft. Question
1988 mustang 2900 lbs w/driver c4 tranny,5400 8 inch conveter 28x10.5
mt slick stock style suspension 4.56 gear aftermarket control arm and tubular k member.
Car ran 10.29 @132.12 with 1.49 60 footbraking.
349ci smblk ford apox. 525 hp.
Just wondering if the 60 ft can be improved and maybe a number I should be working toward.
Thanks.
COPPERN is offline   Reply With Quote
Old 11-02-2011, 11:50 PM   #2
FED 387
Liked 335 Times in 182 Posts
Default Re: 60 ft. Question
you can set up a car to many different things---60 foot---- 1/8th ---1/4---ET--MPH what ever --- just cuz ya have a tremendous 60 foot time doesnt mean that the 1/4 is going to be fantastic too---now if the exact same or similiarly classed car car had a 1.39 vs. your 1.49 and the same 1/4 ET/MPH then you need to pick up your 60 a bit cuz a rule of thumb is for every .01 of 60 double it at the other end and take that time off your 1/4 mile ET and that's what your corrected ET should be--- for example 1.49 =60 and the 1/4 ET is 10.20 so if you could pick it up to say a 1.45=60 your 1/4 et should be .03x2+.06 new ET should be 10.14--- not carved in stone too many variables to consider but I hope this will give ya an idea
Old 11-03-2011, 02:52 AM   #3
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
What low gear you have in the C4?
Old 11-03-2011, 07:37 AM   #4
Chris1529
Liked 70 Times in 29 Posts
What RPM are you leaving at when foot braking?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 11-03-2011, 10:56 AM   #5
west coast
Liked 230 Times in 75 Posts
Aa Greg says Low gear in the C4 2.92 or 2.75 is the common low gear sets for these. If you are at a stock ratio you can inprove a bunch. My Fox body mustang stoker is simular in wieght and rear gear mine is 4.88 and I run the 2.92 first gear in the c4 has had the best 60' of 1.52 et are 11.97. Do you use a 2 step also?
west coast is offline   Reply With Quote
Old 11-03-2011, 11:22 AM   #6
Mile High
Any nitrous? Mine is a stock c4, 4.10 gear, 3120 lbs. with me, no nitrous. Usually 1.50 - 1.52 with 2 step at Bandimere runs 11.20's. San Antonio Nitro Jam last spring consistant 1.42's no 2 step. Footbraking at about 2000 rpm and stab the throttle. Ran high 10.50's -60's. Best 60' Saurday morning 1.405. Lots of fun.
Jeff
Street legal 64 Falcon Sprint with 410W living in Texas.
Stock - Super Stock fan
Mile High is offline   Reply With Quote
