Old 09-26-2011, 10:37 PM   #1
Larry Stewart Sr
Default Msd - ign box repaired
I need phone number he did work for msd at one time thanks
Larry Stewart Sr is offline   Reply With Quote
Old 09-26-2011, 11:39 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Msd - ign box repaired
http://www.techwestracing.com/
Larry Woodfin 471W
Old 09-29-2011, 03:57 PM   #3
Robert Simpson
Liked 20 Times in 12 Posts
Thumbs up Re: Msd - ign box repaired
Pat, thank you for your help. Guys, he really is sharp and knows what he is talking about. Ask him about a ING coil and wait for the response. I chased a problem for almost a year, changed absolutely everything, he made one suggestion, no charge. I did what he said and it helped my problem. So I will say again, thanks Pat you will get a ING from me this year to checkout and upgrade.
Robert Simpson
Robert Simpson is offline   Reply With Quote
Old 09-30-2011, 09:49 AM   #4
Reed Granrt
Robert Simpson
They are extremely sharp. I called to ask about a MSD on my dyno and he told me what coil to use, which help quite a bit, but I put a scope on the box and I still didnt like it so I sent the MSD box to them for their update. really looked great on scope and has never faltered. Have sent many of my customer that way.
reed
Reed Granrt is offline   Reply With Quote
Old 10-04-2011, 09:30 PM   #5
pmrphil
Liked 401 Times in 154 Posts
Pat - When you say to use the Autozone/Carquest coils with the 6AL, are you talking about the older analog box or the newer digital box? What is the downside to using the blaster2? Thanks, Phil
Phil Molski
PMR Performance
S/C 1623
Old 10-09-2011, 09:09 PM   #6
pmrphil
Originally Posted by twrs2006 View Post
pmrphil
The coils I mentioned are for the MSD 6series analog boxes, the Blaster II's ( cylinder style) heat soak quick and loose performance once that happens. The TFI style coils don't heat soak and have solid output for any length of time of use. The coil for best effort for the MSD 6al2 boxes would be the MSD 8253 coil. When your trying to run an index or the same every pass then a drifting coil is not what you want. I hope this helps.
Thanks Pat, I appreciate the info. Phil
Phil Molski
PMR Performance
S/C 1623
Old 10-17-2011, 05:29 PM   #7
junior barns
Liked 20 Times in 14 Posts
pmrphil
Pat, this is what I have used for a long time, (6al, blaster 2). Will this coil heat up fast enough to hurt performance just from driving thru pits and doing burnout? If so where would you see it(start to 8th or 8th to 1/4)??
junior barns is offline   Reply With Quote
Old 10-09-2011, 02:56 PM   #8
68camaroSS
Good Morning
The great questions keep coming, a couple of the common ones are coil matching. For a MSD 6al we recommend either an Autozone C-839 or Carquest FD-478 rather than a Blaster ll. For under $35 dollars and a couple of made up mounting feet you are good to go. As for a MSD 7al2, MSD 7AL3, & the MSD Digital 7 units you can use the MSD 8251 retail around $135. Yes, there is the MSD 8261 coil, if you want the Bling factor than thats the coil for you. Thanks again for the questions and Good Hunting at the final races of the season!
I use the Digital 7 box, and I used to run the Hvac II coil 8261 till I was told by someone that the MSD 8251 coil was a much better coil and had less failure rate.
68camaroSS is offline   Reply With Quote
Old 10-10-2011, 07:51 PM   #9
Phillip marvetz
Phillip marvetz's Avatar
Any thoughts on the Crane Fireball coils? I'm using the PS91 pn730-0091 on a couple of the cars with MSD boxes, 2 with a 6al and 1 with a digital 7.
2009 V/SA Record Holder
Old 10-10-2011, 10:10 PM   #10
L78 Nova
L78 Nova's Avatar
Liked 23 Times in 13 Posts
So,,, When using an MSD 6AL-2 (digital) is an 8253 a good choice for a street car over the blaster 2. Is it worth the extra $140 ?
What is the difference between the 8251 / 8252 / 8253 ?
Thanks for the input.. I'm just replacing my 20+ year old 6AL and Blaster 1... looks like I should have bought more coil.
Gary
L78 Nova is offline   Reply With Quote
