Old 02-27-2011, 05:57 PM   #1
cal
cal's Avatar
Liked 31 Times in 18 Posts
Send a message via AIM to cal
Default Installing a Throttle Stop
OK guys I just got a Biondo throttle.
My problem is I have a GM type cable, can I still Make this thing work?
I keep looking at it, scratching my head and say OK.
Any Pics might help.
I really want to try this Hot Rod Racing this year.
Calvin Starcher
177X HR
cal is offline   Reply With Quote
Old 02-28-2011, 11:52 AM   #2
The LL
The LL's Avatar
Default Re: Installing a Throttle Stop
sorry, can't help you.....only have experience with baseplate stops.
have you tried calling biondo? they are great with customer service.....
The LL is offline   Reply With Quote
Old 02-28-2011, 12:19 PM   #3
jmcarter
jmcarter's Avatar
Liked 3,247 Times in 987 Posts
Provided you have room call Biondo's to exchange for a baseplate style, you'll be happier with the results. And as LL said, they are great guys to deal with.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 02-28-2011, 12:42 PM   #4
Chris Williams
Chris Williams's Avatar
They also have two different styles of connector for their inline stops. I know this because I chose the wrong one, and within an hour of my placing the order on-line, someone called me to say "are you sure"? And of course I was wrong. What amazing customer service.
Give 'em a call, you'll certainly get the help you need.
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 02-28-2011, 03:49 PM   #5
SCOTT SST2871
YOU WONT BE ABLE TO MAKE AN INLINE STOP WORK WITH YOUR STOCK CABLE.WHAT I DID ON MY CAR WAS BUY A FIREWALL MOUNT CIRCLE TRACK PEDAL IT WAS INEXPENSIVE (40or SO DOLLARS) IT HAS A TOE RETURN HOOK MADE ON TO IT ALREADY WHICH IS MANDATORY BY RULES AND MADE A THROTTLE ROD OUT OF 1/4" ROD WHICH WILL THREAD INTO YOUR INLINE STOP.JUST BE SURE TO TO MAKE A POSITIVE PEDAL STOP OUT OF A BOLT THATS ADJUSTABLE
SCOTT FIFIELD
SCOTT SST2871 is offline   Reply With Quote
Old 02-28-2011, 04:45 PM   #6
Ken MacNicol
Ken MacNicol's Avatar
Liked 26 Times in 12 Posts
It will work just fine. Mine has been on the car 15 years.
Buy a CSR throtllle stop cable bracket to mount the exterior cable and the interior cable just fits inside the back of the stop with a lock nut.
Ken MacNicol is offline   Reply With Quote
