Liked 81 Times in 45 Posts
A friend of mine has a bunch of Holley carbs and parts. I can run a 780 on my stocker. Is there any list numbers or metering plate numbers that are better or more desired. He has a GM replacement carb also that is a 780. Any recommendation or suggestions are welcome.
Kirk |
Liked 22 Times in 22 Posts
A 3310 is a 750.
don,t have one |
Liked 8 Times in 7 Posts
Liked 16 Times in 11 Posts
Engine tech spec gives throttle bore measurements, use that to check the carb. If it matches you can use the carb.
Bob Pagano A/SA |
Liked 1,912 Times in 429 Posts
Either buy a Quick Fuel, or call Clark Holroyd, or Jimmy Bridges, tell them what you have, and send them what they tell you they want. You'll be time and money ahead.
Alan Roehrich 212A G/S |
Liked 327 Times in 121 Posts
On my flow bench an old 3310 flowed 788 CFM, an old 4780 flowed 780. I still have a few old 3310s, I bought about 8 of them from a friend back in the early 70s, Paul.
