Old 09-10-2010, 06:40 PM   #1
junior barns
Liked 20 Times in 14 Posts
Question Ignition??
How much should an alternator put out (amps) in order to run an MSD system(6al or ditital 7)????
junior barns is offline   Reply With Quote
Old 09-10-2010, 07:38 PM   #2
sscrewcheif
sscrewcheif's Avatar
Send a message via Yahoo to sscrewcheif
Default Re: Ignition??
it only needs to put out enough to keep the battery charged.... the ignition runs off of the battery. If the battery is charged to capacity then you shouldn't need an alternator on at least 4 passes back to back type runs.
Big wheelies are for show!!
Go fast or go home!!!
sscrewcheif is offline   Reply With Quote
Old 09-10-2010, 08:25 PM   #3
junior barns
Thanks
are the amps or the volts more important? My alt is puting out 40.6 amps and 14.08 volts at 2000 rpm. The box says it is a 50 amp alt!
Old 09-10-2010, 09:14 PM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
How did you measure 40 amps ? If the load on the alternator is lower than 50 amps , then that's all it will put out . I think a MSD-7AL uses about 12 amps, depends on the rpm .
ss3011 is online now   Reply With Quote
Old 09-10-2010, 09:59 PM   #5
junior barns
Hooked out tester up then it said to bring rpm up to 2000 rpm and hold (approx 30sec) then it said to let idle (again approx 30 sec) test done. And this was the reading I got>
And the idle amps were around 29
Old 09-13-2010, 04:24 PM   #6
sscrewcheif
That sounds pretty normal....assuming you tested it load free?
