Old 08-22-2010, 06:07 AM   #1
Ben Kallies
Default Fuel System - NPT Thread Sealant
What's the best product to use for sealing NPT threads in a fuel system? I've used both teflon tape and ARP thread sealant with good and bad results from both. Is there a better alternative? Thanks.
-Ben
3869 B/S
Ben Kallies is offline   Reply With Quote
Old 08-22-2010, 06:45 AM   #2
Bob Verwold
Bob Verwold's Avatar
Default Re: Fuel System - NPT Thread Sealant
I thought the ARP goop worked pretty good.
Bob Verwold is offline   Reply With Quote
Old 08-22-2010, 08:33 AM   #3
FED 387
Liked 335 Times in 182 Posts
Both of those work well ya just hafta make sure ya dont get any tape over/past the threaded ends other wise it works loose and clogs up later on----Comp
Old 08-22-2010, 03:00 PM   #4
Dragsinger
Liked 99 Times in 60 Posts
take a look on the Permatex web site. You will see several choices. The one listed below has given good service.
http://www.permatex.com/products/Aut...ad_Sealant.htm
Old 08-24-2010, 11:26 AM   #5
Ben Kallies
Thank you to all who responded. I think I'll give the Permatex a try.
-Ben
Old 08-24-2010, 12:06 PM   #6
W J
Do a search on Leak-Lok thread sealants. I've been using this product for 25 yrs. + on threaded joints on gasoline and other fuels in the automotive field w/great results. I use the Leak-lok blue. WJ
Old 08-24-2010, 12:33 PM   #7
SSDiv6
Originally Posted by dragsinger View Post
take a look on the permatex web site. You will see several choices. The one listed below has given good service.
http://www.permatex.com/products/aut...ad_sealant.htm
x2
