I am looking for pictures of Alf Wiebe's setup.
I have been trying to purchase it but cannot, So I would like some detailed picture so that I can make my own. Or maybe just some pictures of what works for your Chevelle. I am a small time bracket racer that is having trouble hooking up/ Thanks for your time. Ron |
I'm using a Moser 12 bolt, the ears are raised on it 1.5" above a GM 12 bolt. I am using all stock location mounting points in the rear, Moog oem replacement springs, QA1 single adjustable shocks, www.hrpartsnstuff.com bolt-on antiroll bar. I am also using polygraphite bushings in my front, stock, upper and lower control arms, Santhuff springs and shocks also. Puttin it all to the ground with Hoosier 30x9x15 radial slicks.
*** 72 Malibu *** 1.329-3.99-6.28@106.71-9.98@131 best 60ft to date-1.2997 |
#3 | |
Liked 165 Times in 51 Posts
I SEE ONE FORSALE ON RACING JUNK UNDER SUSPENTION
http://www.racingjunk.com/category/1...2-a-body-.html Quote:
Wow, 1st time I've actually seen Wiebes work. That's some engineering involved there. Now I see why those A-bodies with his suspension work as well as they do.
Jeff Lee 7494 D/S '70 AMX |
Liked 3 Times in 1 Post
Does anybody know if this is the original setup or the latest version?
Liked 1,761 Times in 400 Posts
Advertised as the latest.
Alan Roehrich 212A G/S |
#7 | |
Alf's system is 100% legal. I don't know the specifics behind all the rules controversy as I am just a bracket racer, but everything was ironed out and it is approved by NHRA, and I know of 1 car for sure that also runs IHRA events using his system. I do know the newer system mounts directly to the stock LCA mount. No welding of any kind involved with either the earlier or latest system.
Liked 6 Times in 4 Posts
More discussion on Alf Wiebe's "system".......
http://www.classracer.com/classforum...ad.php?t=14156 |
