Old 12-07-2009, 05:47 AM   #1
Bobby Zlatkin
Bobby Zlatkin's Avatar
Default 3rd generation Camaro
Was wondering what was involved in changing out the 700R4 for a Turbo 350.
Is the trans a different length?
Will the driveshaft need to be lengthened/shortened?
Is trans mount in same location?
Can the original crossmember be used and in the same location?
How about the tunnel, any problems there?
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 12-07-2009, 07:35 AM   #2
Liked 1,789 Times in 408 Posts
Default Re: 3rd generation Camaro
A TH 350 is shorter than a 700 R4, and the mount is closer to the front. No, the original crossmember cannot remain in the same location. No problems with the tunnel. If you can find a car that was built with a 200 Metric, the crossmember, mount, driveshaft, and torque arm mount are where you need them. You will have a very hard time finding a TH 350 extension housing with the mounting holes and mounting bosses for the torque arm brackets.
Old 12-07-2009, 09:31 AM   #3
Ron Middleton
Liked 12 Times in 4 Posts
B&M makes a reasonably priced and simply bracket for the torque arm. Part No. 30299. Use the stock driveshaft for 1982 Camaro with TH200.
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.”
- Aristotle
Ron Middleton is offline   Reply With Quote
Old 12-07-2009, 10:05 AM   #4
bobby
bobby's Avatar
You can get on www.LS1tech.com there are guys over there that are putting th400 and 4l80 into these cars.
Next time wave all of your fingers at me.
bobby is offline   Reply With Quote
