Is a small journal 327 sbc dated from 1967 ok to build for a race engine?I have one in my garage.Or should i get a large journal 350 block and go that route?Also how do you get that baffle out that is in the lifter valley?thanks alot Gene.
Liked 205 Times in 93 Posts
the engine displacement depends on what class you plan to run. remove the 1/4" bolt holding the breather in place, tap the unit out with a flat driver.
Liked 319 Times in 108 Posts
It will work but if cubic inches don't matter& on budget build 350most available parts cheapest.Sell 327 to someone wanting that date.
Mike Taylor3601 |
I was thinking the same thing.I was looking into the dart 372 sbc shortblock.Pretty cool read up in chevy high performance mag.This is just for a bracket car.
If buying Dart go with biggest cubic inches won't cost anymore crank/piston cost same.
Mike Taylor3601 |
