Old 01-17-2009, 11:37 AM   #1
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Disc brake pads...
Looking for recommendations for the best pads (brand and part#) for front, Aerospace/Wilwood type, "drag race" disc brakes.......
3500 lb car (GM "A" body), in the 10.50 ET @ 126 MPH range. TIA
Old 01-17-2009, 09:06 PM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: Disc brake pads...
try contacting hawk brakes they make pads for most of the aftermarket companies. they have many different compounds to suit your needs.
Mark Markow is offline   Reply With Quote
Old 01-18-2009, 09:17 AM   #3
rallye bob
rallye bob's Avatar
Wink Re: Disc brake pads...
Thank you for your reply quadfather.
I did just that, but all the different compounds confuse me. Thought I could find someone on here that has already done the R&D for me....
Old 01-18-2009, 06:03 PM   #4
Mark Markow
the compound depends on what your needs are. i.e. static holding power on the starting line. or better stopping at high speeds ect. just give them a call the'll sort it out for you.
Old 01-19-2009, 09:08 AM   #5
Jim Kaekel
Liked 536 Times in 110 Posts
Hawk Brake's DR 97 pads are specifically for drag race cars, their Black (medium torque) pads are for moderate drag applications. Wilwood's Polymatrix "B" or Polymatrix "E" pads are best for drag race. You will need to specify which series of caliper (Dynalite, Superlite?) you have.
Jim Kaekel 3836 STK
Old 01-19-2009, 10:21 AM   #6
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Best pads I've used for the Stocker or the SG car. ....The local Stock Car boys tuned me into Hawk a few years back. ...........Call the tech guys at Hawk with your application, they are really helpfull, Especially when it comes to a foot brake application ,where you need a good cold holding pad. .....Tom
Old 01-19-2009, 12:48 PM   #7
Raceready
I use the polymatrix e pads on my 3300 lb 10.70 A body.Good pads,stop well and will hold the car up to 2400-2500 rpm on the footbrake.
Raceready is offline   Reply With Quote
