Old 05-16-2008, 07:49 AM   #1
40Coupe
Default Quicker 60 foot with 2-step
Is your footbrake car quicker in the 60' off a 2-step?
'67 Camaro
1.25
5.77 @ 118
40Coupe is offline   Reply With Quote
Old 05-16-2008, 01:05 PM   #2
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Default Re: Quicker 60 foot with 2-step
All depends. 455 likes to leave from idle. 283 likes 4500 on the floor. If your somewhere in the middle all you can do is test.
Daran Summerton is offline   Reply With Quote
Old 05-16-2008, 04:50 PM   #3
tpoh815
tpoh815's Avatar
Liked 28 Times in 11 Posts
Thumbs up Re: Quicker 60 foot with 2-step
i agree with daran. suspension will also like or dislike it.
EX 5-Doorstocker
tpoh815 is offline   Reply With Quote
Old 05-16-2008, 06:31 PM   #4
40Coupe
Thanks for the response but I think you might have missed my question.
I can currently leave anywhere from idle to 3000 RPM off the footbrake and the car 60 foots the same. However my reaction time does improve the higher the leave RPM.
My question really comes down to, will the car 60 foot quicker and hit the converter harder by leaving off a two-step (eliminating the carb pump shot) assuming the same current footbrake launch RPM?
'67 Camaro
1.25
5.77 @ 118
Old 05-16-2008, 08:02 PM   #5
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
if its any constilation,my 4 speed use to 60' better not using the two step,rather than on it ,i set the two step at 4000 rpm and with out i would leave a 3500 rpm and slam the gas to the floor as i dropped the clutch i guess i depends on what your car likes gmonde
gmonde is online now   Reply With Quote
Old 05-16-2008, 10:21 PM   #6
SSDiv6
Too many variables are involved. Engine torque curve, carburation, weight, suspension set up, stall/flash RPM, or clutch set up.
