Just wanted to get an opinion as to how you guys are making out with the new two step rule? I read an article that Peter Biondo was having a hard time a couple of weeks back.
Also, how are you mounting the switch to the brake pedal and what kind of switch (brand) are you using? We haven't made the modification yet and would like some tips regarding how to do it the right way. Thanks |
Liked 1,928 Times in 434 Posts
I don't know that I'd consider winning the Gators as "having a hard time".
![]() I know some people using a switch in the pedal itself, and some using a switch mounted in place of the brake light switch. I think Biondo's has several switches available, and I'm told they're very helpful.
Alan Roehrich 212A G/S |
Liked 19 Times in 7 Posts
I was going to put a 2 step switch in place of the brake light switch but I was concerned about (1)the switch being on untill the pedal traveled enough to close the loop and (2) the 2step engaging when you hit the brakes at the big end. EX. going from 7800 to 3000rpm has to be hard on the rotating assembly. I could be over engineering I guess. Im using the original clutch pedal with a button to leave the line and that pedal is now locked and moves together with the original brake pedal. Kinda like two pedals working as one.
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
Yeah i agree Alan. If his .002 to my .001 third round gators is having trouble i would love to have that problem. Don't have one on the car yet just footbrakin it. Not sure if i want too.
#5 | |
#6 | |
Im going to wait untill we hit the first national event and see if what I have is even legal. The car is fresh with 0 runs on it but in the driveway it works pretty slick!! Almost like leaving with a clutch but without the breakage. hahaha. I would kill for a Jerico!!!
Liked 3 Times in 2 Posts
Hey crate....how you going to get past the head tech guy with this goofy setup?
FJ |
