Old 01-22-2024, 05:30 PM   #1
sean1970ss
Liked 10 Times in 6 Posts
Default Flywheels has little bit of glaze from clutch disc went bad
Had a clutch disc go bad it made some glaze on the flywheel nothing bad. Would it be alright to use some sand paper to knock it off? orbital sander?
Also with a diaphram set up how much clearance between the throw-out bearing and fingers? 1/4?
sean1970ss is offline   Reply With Quote
Old 01-22-2024, 07:58 PM   #2
Mark Ugrich
Liked 71 Times in 38 Posts
Default Re: Flywheels has little bit of glaze from clutch disc went
My advise would be to remove the flywheel and have a machine shop take a light cut to remove any glazing or heat spots. That way you know for sure the flywheel is flat and you won’t be doing it over because the clutch chatters or has other issues. 1/4” sounds about right on the clearance.
Old 01-22-2024, 10:18 PM   #3
sean1970ss
I went ahead and took it off. Friends car I told him I just don't like it rather have it right then gamble. Appreciate the response to. Sean
