Liked 973 Times in 195 Posts
What year starter do I ask for when ordering a staggered bolt pattern aluminum snouted starter for my sbc 168 tooth flywheel starter? the one on my 55 is noisy and want to get a spare.
Liked 84 Times in 21 Posts
Powermaster lists what you are looking for in their starter choices. They show 8 different performance starters from OE right up to their Ultra Torque with the configuration your looking for. To date I have had zero issues with their products your results may differ.
Liked 20 Times in 15 Posts
Don't you need a bell housing mount starter and not a block mount starter for the '57 #3731548 block? I only have a Tilton mini starter # which is 54-00015.
Liked 133 Times in 76 Posts
I called House of Payne about a starter for my car. He told me save your money and buy a GM mini starter reman # 6449 for a late 90's truck fits all the way up to 8.1L. You just have to be sure to get the correct bolts as they are a little shorter. You can find high torque reman and new on ebay and they work great. For me it works even better as my tow vehicle is a late 90's truck so the spare I have fits the racecar and the tow vehicle.
https://www.ebay.com/itm/18471381448...oAAOSwIGhgUMZ4 |
Banned
Liked 179 Times in 89 Posts
Thanks for the info on the aftermarket starters,but I need to go down to the auto parts store and get a original style starter as I need to have it on the car in a day or so.
Liked 481 Times in 158 Posts
1980 Camaro 5.7 / 350 ci, auto trans, if you wish they can cross reference AC Delco 336-1824
#8 | |
Liked 520 Times in 176 Posts
I believe the starter that's in my 454 (7.4 Liters - ugh!) 1989 20 series Surburban 2wd, Auto transmission is the staggered pattern and High Torque. They call it a 2500R series if you have to go to an Auto Zone or Parts Authority or one of the Chain parts outlets. I hope this helps. Respectfully, Henry Kunz 1534 H/SA |
Liked 4 Times in 3 Posts
U can even get the Late Model OEM Mini Starters in Staggered Pattern---I wish you lived closer I have both
Liked 293 Times in 65 Posts
Lynn - I have a factory mini starter on my 68 Camaro w/ 400 sbc. Just ask for a starter for a 1998 K1500 w/ a 350. It's staggered bolt pattern and works great with the headers.O'Reilly part number is N613326A.
