Old 06-26-2021, 01:16 PM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Default Scale and Weighing Accuracy Question
Recently converted a livestock scale to a scale that will weigh one wheel at a time. If all wheels are exactly level including the scales, is there any reason I will not get an accurate weight adding all 4 corners ??? The scales are dead accurate and calibrated. Thanks for any opinions.
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 06-26-2021, 01:27 PM   #2
Ralph A Powell
Liked 227 Times in 138 Posts
Default Re: Scale and Weighing Accuracy Question
I used to two of those scales and wooden block risers of the same height as the scales for the other two wheels. No problems with this set up. They belonged to Wayne Gapp! That’s what he used.
Old 06-27-2021, 05:10 PM   #3
SSDiv6
You should not have an issue.
Probably more accurate than the scales at many racetracks!
Old 06-28-2021, 11:01 AM   #4
Henrys Toy
Liked 520 Times in 176 Posts
Good morning, as long as the scales are equal heights to each other , those scales will be accurate. Also try to get the wheel/tire as close to the middle of the scale will help as well. I know sometimes wheel offset and body overhang might push the scales from the centers of the wheels. Also - Please be sure to put the car in "Park" or in "Gear" so it doesn't roll off the scales. The other posts here are also very good information.
Respectfully,
Henry Kunz
1534 H/SA
Henrys Toy is offline   Reply With Quote
