Old 06-13-2016, 01:52 PM   #1
pfordamx
Liked 7 Times in 5 Posts
Default 70 amx 360 carb
can anyone clarify what the blue print sheet is saying under carb for 1970 290hp 360 amc combo becuase i think it should be a autolite 4300 4bl but all the blue print sheet says is (owa-4/auto) i'm pretty positive the /auto is specifying a automatic trans and i've looked through the accepted parts list and didn't see a reference to this. any help would be appreciated
(290 360 10.0 1-4 Ford 0WM-4/SM 0WA-4/AUTO)
pfordamx is offline   Reply With Quote
Old 06-13-2016, 02:05 PM   #2
DeuceCoupe
Liked 48 Times in 44 Posts
Default Re: 70 amx 360 carb
I have run a lot of Ford 4300's so now & then I obtain an AMC 4300.
AFAIK, AMC used the Carter AFB thru 1969, then went to the Autolite 4300.
Ford made 2 sizes for the 4300:
1.00" venturi, about 440cfm
IIRC this was only used from 1967-69.
1.25" venturi, about 600cfm
This was used from 1968-1974.
In the AMC numbering, 1st digit is the year, 3rd digit is a=auto or m=manual, and I think last digit means 4bbl.
I've had:
3tm4
3ta4
4ta4
I don't know what the 2nd digit "T" vs your "W" means.
All the 1.25" venturi Autolite 4300's are the same CFM so I bet any of them would be legal, the only diff is jets & air bleeds etc.
Old 06-13-2016, 02:07 PM   #3
Bobby DiDomenico
Liked 101 Times in 52 Posts
Have a friend who moved to Phoenix a while back with 2 AMC's. Isn't this the same 600 cfm carb on a 70/71 351 Ford?
0 = 1970 W = engine size M = Manual & A = Automatic 4 = 4V
Old 06-13-2016, 03:23 PM   #4
pfordamx
i think it is the same 600cfm carb that ford used and that being the case do you guys have a builder you would suggest? i know Deano is the man on quadrajets , so who knows autolites also makes me wonder if there is a quickfuel or replacement option but i haven't seen one.
it would be great if i could use any 600cfm carb i wanted.
Old 06-13-2016, 03:27 PM   #5
pfordamx
and i guess its a motorcraft not a autolite unless there the same i don't know fords that well.
Old 06-13-2016, 03:33 PM   #6
Bobby DiDomenico
Somewhere before or by the early 70"s I recall my boxes going from Autolite to Motorcraft at the local Ford dealer.
Old 06-13-2016, 05:55 PM   #7
rawhide
during the 60's Ford used Autolite as a trade name for a lot of parts. The government for some reason sued Ford and made them sell the spark plug division so Ford started using Motorcraft for their parts and Fram/Allied Signal ended up with Autolite.
Roland
rawhide is offline   Reply With Quote
