Old 08-11-2015, 07:28 PM   #1
Woodfin
Liked 288 Times in 109 Posts
Default carb air entry pan for the Super 10
is this Quick Fuel air bell a legal SS part?
http://www.quickfueltechnology.com/s...150-style.html
Old 08-11-2015, 08:02 PM   #2
SSDiv6
Default Re: carb air entry pan for the Super 10
It's not legal.
The air cleaner rule you have to follow is the same as for Super Stock class.
AIR CLEANERS
Optional. If used, air cleaner must be OEM automotive or retain
OEM configuration. Air-cleaner base may be cut or trimmed, but
welding, bolting, riveting, epoxying, or any other form of fabrication
prohibited. Ram tubes, velocity stacks, or other than stock-type
base plates or ducting prohibited. Cooling holes prohibited in
radiator side panels, etc. Factory air cleaners and/or scoops that fit
through hood must be affixed to carburetor as per OEM only.
Old 08-11-2015, 09:28 PM   #3
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: carb air entry pan for the Super 10
X2,,, that's basically a velocity stack you're looking at, Larry.
Danny Durham
Old 08-11-2015, 10:40 PM   #4
MAURICE BLENDHEIM
Liked 287 Times in 88 Posts
Larry…Classic Industries Part number C695, should keep you out of trouble. MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 08-12-2015, 04:09 AM   #5
Dragsinger
Liked 99 Times in 60 Posts
Maurice,
Thanks, I need a non trouble situation
Larry Woodfin 471W
Old 08-12-2015, 08:32 AM   #6
Danny Ashley
Liked 110 Times in 29 Posts
Larry,
Not sure exactly what you are wanting but if you need an air cleaner base, then check out Speedway Motors' #91011062-2. At only $14.99 you can't go wrong. This is what I used to recommend to my carb customers when they asked about air cleaner bases. They also offer it with a top if you want to run a filter, #91011000. It comes with your choice if spacer 1/2, 1, or 2 inch and a stud. Hope this helps. Regards, Danny
Danny Ashley is offline   Reply With Quote
