Location: Trussville, Alabama-Originally from Vidalia,GA
Need some help on a 07 5.3 GMC Sierra pickup. The warning message comes on the windshield washer is low every time I start it up, but it's not
it's full. Goes off when I reset the mileage. Any help would be appreciated. FrankChastain |
Liked 216 Times in 77 Posts
Take a look at the sensor in the tank. It probably has something on it. After you clean it or replace it ( I would recommend replacing it). IF you dont have a scan tool to reset it. Sometimes you can disconnect the battery for 2-4 hours and it will reset. While you are at it take a look at the connector in the wiring harness and make sure it is not corroded. If it is you can get a new one from NAPA.
#3 | |
Thanks Rob for the info.....Thanks again Frank |
