Old 05-12-2014, 03:38 PM   #1
Chris Hall
Default Metric 200 fluid level
When measuring from the trans pan flange, what trans fluid level is best with a Metric 200 with a deep pan?
Chris Hall is offline   Reply With Quote
Old 05-12-2014, 03:45 PM   #2
Jim Kaekel
Liked 531 Times in 108 Posts
Default Re: Metric 200 fluid level
See Tech Tip #12 on the Turbo Action web site under Tech Tips. There is a full explanation.
Jim Kaekel 3836 STK
Old 05-12-2014, 04:16 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
The factory oil level is, full hot even with the pan gasket.
Old 05-12-2014, 04:48 PM   #4
Greg Hill
Liked 279 Times in 68 Posts
I always run ours about 1 qt. low when cold. That equates to about 1/2 qt. low when hot. Those things are bad about puking fluid out if they are full.
Greg Hill 4171 STK
Old 05-12-2014, 07:16 PM   #5
G Anderson
Liked 4 Times in 3 Posts
I got on the T-A web site and it calls for about 5/16" down from the pan rail and it says you might have to remark aftermarket dip sticks"this would explain why my 2 dipsticks have different levels" Thanks for the info Jim Kaekel !!!
G Anderson is offline   Reply With Quote
Old 05-14-2014, 12:12 AM   #6
Chris Hall
Thanks for the info! I'm just trying to get my pile to be a little more efficient
