Old 04-20-2014, 12:58 AM   #1
rs6868
Default Cross member 4sp Jerico in 67 Camaro??
Hey guy's...question for you blokes running Stockers with a 4sp Jerico in a 1st gen Camaro...I've got a 67 Camaro and I'm fitting a DR4-4 Jerico...I've purchased the factory 4 speed cross member from Classic Industries but with a factory rubber GM trans mount it sits the transmission way to high in the tunnel...what do you guy's use for a cross member and trans mount when running a Jerico or is a custom cross member the only option??
Thanks in advance,
Ross.
rs6868 is offline   Reply With Quote
Old 04-20-2014, 01:14 AM   #2
Jim Hawkins
Liked 115 Times in 35 Posts
Default Re: Cross member 4sp Jerico in 67 Camaro??
My 67 camaro with a Jerico trans. has a custom crossmember. Not sure how much different it is as far as height from a stock crossmember. Never had a stock one in the car.
Jim Hawkins is offline   Reply With Quote
Old 04-20-2014, 05:31 AM   #3
Greg Barsamian
Liked 427 Times in 97 Posts
Had to cut & re-weld the "saddle" or "mount" on the cross member in my Chevelle in order to lower the angle of the transmission to the rear end.
Old 04-20-2014, 10:46 PM   #4
Run to Rund
Liked 56 Times in 29 Posts
The Jerico DR4 was a bolt-in for my 66 A body, except that I trimmed down a couple ribs on the top cover for more clearance to the hump.
