Old 05-08-2012, 03:17 PM   #1
Chad Rhodes
Default Driveshaft Speed Sensor
will mounting it to the slip yoke on the transmission work ok?
Chad Rhodes 2113 I/SA
Old 05-08-2012, 03:46 PM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 278 Times in 78 Posts
Default Re: Driveshaft Speed Sensor
The amount that your suspension moves the slip yoke, away from the sensor may make it unreliable.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 05-08-2012, 04:31 PM   #3
Chad Rhodes
Sean
that's exactly my concern
Old 05-08-2012, 06:54 PM   #4
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
I have mine mounted on the slip yoke with no issues whatsoever. The kit gave us no alternative.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 05-08-2012, 07:08 PM   #5
Bill Harris
Liked 26 Times in 13 Posts
It will also depend on what sort of sensor your DA is using. If it is a magnetic reed-switch type it will probably be unreliable as the distance between the sensor and the magnets change. If it is a Hall-effect sensor, it likely will work just fine. It also depends on the strength of the magnets in your ring.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 05-09-2012, 07:04 AM   #6
race watcher
I have installed a few on slip yoke with no problems.
race watcher is offline   Reply With Quote
