Old 03-04-2012, 09:12 AM   #1
ant1277
Default Front springs
I have a 72 Nova stock front end, backhalf style car with a big block. I don't class race just bracket and super street. I need to put new springs in the front. The car with driver is 3105 lbs. The front is 1705 lbs. with driver. What are some of you using in your stock and super stockers. I realize my weight may be lighter than some of yours. How are you coming up with the correct spring rate and where to get them. Thanks
ant1277 is offline   Reply With Quote
Old 03-04-2012, 06:35 PM   #2
72Malibu
72Malibu's Avatar
Default Re: Front springs
Call Ron at santhuffshocks.com
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 03-05-2012, 08:16 PM   #3
M Brand 505B
Liked 31 Times in 10 Posts
Santhuff is the way to go.
Michael Brand II
505B - F/SA
M Brand 505B is offline   Reply With Quote
Old 03-05-2012, 09:10 PM   #4
40Coupe
Santhuff's here. Can't keep it off the bumper.
'67 Camaro
1.25
5.77 @ 118
40Coupe is offline   Reply With Quote
Old 03-05-2012, 10:13 PM   #5
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
you ain't been on the bumper yet and I used Moog springs on my stock suspension Chevelle...
That said, who makes the spring isn't important, what is important is that you use the tallest spring that will fit with a wire diameter heavy enough to the support the nose weight within 10%, that when compressed at ride height results in a air gap of no more than 1" between the factory snubber on the lower control arm and it's point of contact on the frame
Old 03-05-2012, 11:36 PM   #6
HP HUNTER
Liked 373 Times in 129 Posts
Man Ed, that front end is all over the place, good advice though!
