Old 02-29-2012, 04:27 PM   #1
racer913
Default control arm bushings for 1st gen camaro
rebuilding front end on my 67 camaro I could just some help deciding who makes good bind free bushings
racer913 is offline   Reply With Quote
Old 02-29-2012, 04:44 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: control arm bushings for 1st gen camaro
Global West, Afco and others. That said, the same can be accomplished by modifying poly graphite bushings by adding a zerk fitting, cutting a grease groove in the bushing and turning down the sleeve which is what I had on my Chevelle.
Old 02-29-2012, 05:35 PM   #3
Chad Rhodes
actually no it can't. The poly bushing will still deflect, albeit less than the stock rubber one. The Del-A-Lum style that global west sells will not and will still move just as free if not more so.
Chad Rhodes 2113 I/SA
Old 02-29-2012, 05:38 PM   #4
1320racer
1320racer's Avatar
worked well for me, footbraking my 3880 lb, Chevelle to a 1.28 best 60 foot with 59% of that weight on the nose.)
Old 02-29-2012, 05:40 PM   #5
Chad Rhodes
whoopdie f'n doo. I was just pointing out that no, "the same can't be accomplished" by modifying a poly busing. Deflection may not matter to you, but to a lot of class racers it does. Since you aren't one, you don't get it.
Old 02-29-2012, 05:52 PM   #6
1320racer
1320racer's Avatar
oh I forgot, only class racers get it.
FYI, one of the best stock/super stock builders in the country disagrees with you.
