Old 12-17-2011, 05:14 PM   #1
Fastang
Default .430 Valve lift for everyone?
The NHRA rule book says that if you are running stock with a front-wheel-drive or stock truck, your maximum lift is .430 or OEM which ever is greater. I am running a '77 Pinto with the 2.8L V6 that has .391/.391 stock lift. Can I run .430 lift or does that only apply when this same engine is in a For Ranger truck? Anybody run across this? Thanks.
Fastang is offline   Reply With Quote
Old 12-17-2011, 06:43 PM   #2
mtkawboy
Liked 54 Times in 18 Posts
Default Re: .430 Valve lift for everyone?
It pretty much spells it out to me. Pintos arent trucks or front wheel drive but who knows. Get rid of the fiber top timing gear on your V6, they dont last in stock ones. Put lifters in motor before bolting heads down or you cant get them in . Former Ford mechanics advise.
mtkawboy is offline   Reply With Quote
Old 12-17-2011, 06:49 PM   #3
Fastang
Thanks for the tips. I've done both already. I think I'll poke NHRA on this though it could be a waste of time. Never know until you try.
Old 12-17-2011, 08:18 PM   #4
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Exclamation Re: .430 Valve lift for everyone?
The .430 lift rule is for FWD vehicles only. A Pinto is not a FWD car. Trust me, I helped write some of the rules many years ago. Jim
Old 12-17-2011, 08:37 PM   #5
Jeff Lee
Jeff Lee's Avatar
Ford would have to be behind you with that and I seriously doubt that will happen. Do yourself a favor, don't bother tech with such a silly idea. Because they will NEVER listen to you even if you have legitimate grievances.
Jeff Lee 7494 D/S '70 AMX
Old 12-17-2011, 09:12 PM   #6
Liked 5,121 Times in 1,952 Posts
How are you going to claim a truck engine when it doesn't show the truck in the guide for 77?
...And that, my friend is the least of your problem with that combo.
