Old 09-26-2011, 10:21 PM   #1
art leong
Default Stamped rockers?
Have any of you that have used stamped rocker arms. Had them wipeout on the valve tip side?
What are the causes (other than lack of oil) ?
I'm using a cam that is much bigger than a stock cam. And I destroyed 12 out of 16 rockers
Art Leong 2095 SS
Old 09-27-2011, 12:51 AM   #2
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Question Re: Stamped rockers?
Artie, is this the problem you were chasing? Jim
Old 09-27-2011, 08:37 AM   #3
BlueOval Ralph
Banned
Default Re: Stamped rockers?
Art First off find the post I put on here about the blends of Mobil One the new oils don't not have enough of additives for flat tappet cams and followers. If you lookat the Mobil web site you will find their blends with the extra additives. Look at. The Porsche special blends they have the extra, Porsche is one if the few that still use directing acting followers (no roller finger followers). My first guess is that you lave a lube issue could have started at break in
mobil.com/USA-English /motoroil/files/mobil_1_productguide
BlueOval Ralph is offline   Reply With Quote
Old 09-27-2011, 08:52 AM   #4
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
Yes, I have. Come to find out it was the rockers. They were suppose to be the "all high mighty nitro" rocker which (no names) one of the cam manufactures sells. Chinese steel junk.
I found a set of OEM and did hardness testing against the Chinese rockers. WORLD of difference. I suggest checking hardness. Should be at least 40-45 on rockwell C scale.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 09-27-2011, 04:50 PM   #5
art leong
here is a picture of my rockers. The one on the left is a good one the one on the right is wiped out.
Art Leong 2095 SS
Old 09-27-2011, 05:46 PM   #6
James Perrone
Liked 1,867 Times in 436 Posts
Art
Since I have had my rockers treated by Jim Baileys.company
Have not broke any with my sb in 2 years.Great investment at a great price..
And they still look awsome..Good luck
james perrone 1290 STK
Old 09-27-2011, 08:09 PM   #7
Tom Turner
Jim Bailey's Company is called?? Website? Phone #?
Tom Turner is offline   Reply With Quote
Old 09-27-2011, 08:50 PM   #8
art leong
Originally Posted by James Perrone View Post
Art
Thanks for that. I'll call him tomorrow
http://www.finishedracing.com/
Art Leong 2095 SS
Old 09-27-2011, 09:32 PM   #9
Adger Smith
Liked 880 Times in 311 Posts
Art,
Just a guess here, but the new bigger cam had a smaller base circle/root diameter and it moved the lifter pivot point and the valve end lost it's rolling couple. It started sliding across the valve instead of making a roll across as it lifted. I would venture to guess your rockers on the bigger lift lobe had the most wear.. In the past I did a lot of the 2300 Ford ohc 4 cylinders and if you didn't get the rocker set up right it would do bad things to the valve gear as well as not run very well. Put that other head together with the older/smaller cams. Sorry I missed your call this afternoon. I'll try to get you in the morning.
Adger Smith (Former SS)
