Old 10-26-2010, 03:56 PM   #1
Kevin Love
Liked 19 Times in 10 Posts
Default 2011 Stock/Super Stock Rule Changes
NHRA has rule updates for 2011 listed on NHRA.com
Quick review:
Stockers back to 1955
Valve springs in stock
Parachutes in stock (over 150)
Maximum weight limits
Gloves/neck collars for more classes
Trans shields/flexplates/flexplate shields in more classes
Wagons in SS/GT
Listed on front pages under Racer Updates
Kevin Love 5666 STK/SS
Kevin Love is offline   Reply With Quote
Old 10-26-2010, 04:08 PM   #2
novassdude
Liked 136 Times in 49 Posts
Default Re: 2011 Stock/Super Stock Rule Changes
Am I understanding this one correctly. You can not run heavier than the next lower classes Minimum weight? So there will be no more running 300 pounds heavy to slow down cars?
WEIGHT
All cars will be permitted to run on the class minimum weight, but may be no heavier
than the minimum for the next heavier class. Car can move up (lighter) one class or
down (heavier) one class. If weight is added, must be properly attached; see BALLAST.
Class and classification weight are determined without driver weight. Once classification
weight is calculated, 170 pounds is added for driver to arrive at total weight. All cars are
weighed with driver.
novassdude is offline   Reply With Quote
Old 10-26-2010, 09:49 PM   #3
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
WEIGHT
HOLY COW! They actually did this?! I've been running that one up the flagpole for two years now! Good, common sense rule. -=applause!=- Thank you, NHRA!
Re: AAF/S.... uh, why don't they create some realistic weight breaks for the FWD classes instead of tacking onto the top? It's not like there are no letters in the alphabet past "E". While the "big cars" fight full-pound weight breaks because they'd have to "carry so much weight", what about the weight difference between DF/S and EF/S... 2,241 vs 2,895. 650LBS? SERIOUSLY?!
Old 10-27-2010, 08:54 PM   #4
GarysZ24
GarysZ24's Avatar
Liked 256 Times in 103 Posts
Thumbs down Re: 2011 Stock/Super Stock Rule Changes
I couldn't agree with you more Michael!!!
Gary Hampton
'86 Z24,173 V6
CF/S #5824 (#78 in 2021)
Old 10-27-2010, 09:28 PM   #5
Adger Smith
Liked 880 Times in 311 Posts
About the block rule: a NHRA approved aftermarket cylinder blocks" for s/ss
That is good news for the V-6 guys. Since GM has quit casting the Bowtie V-6 block there is a shortage. Brian Browell has stepped up and had blocks & heads cast and NHRA approved. That just about seals the deal on the new V-6 blocks for Comp through Stock. Since we can't count on GM or other MFG's to continue to supply parts I think it is the next step for NHRA to modify the rules to help us keep racing.
Adger Smith (Former SS)
Old 10-27-2010, 10:59 PM   #6
Barnstorm
Barnstorm's Avatar
Blossom digs out the old AT/SA Syclone and puts 30lb of boost in with an aftermarket alum block......
Old 10-26-2010, 04:15 PM   #7
Smile Re: 2011 Stock/Super Stock Rule Changes
Quick review:
Wagons in SS/GT
Terrific - I'll start building my "Black Widow" '57 Bel Air 283 / 250hp powerglide car ASAP .......Or at least when the economy changes .
Old 10-26-2010, 04:31 PM   #8
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Jack, me first!!!!!!
Wade O
Old 10-26-2010, 08:33 PM   #9
Tony Janes
I think the 245 hp is better then the injection 250 hp. I have a friend with a 57 bel air body, like my car from the sixties, but not the 25,000 or so dollars to build it.
Tony Janes 7941 STK, SS
Tony Janes is online now   Reply With Quote
Old 10-26-2010, 08:56 PM   #10
MYRONARL1119
Does this mean it is a good time to dig my ole 57 chevy injection unit and the matched set of heads out of the garage, and advertise as "stocker builder up material"? Or better yet, does this mean that it is time to start searching the yards for a wrecked Impala SS car for stock. Seems like possibly a 303 hp LS4 v8 front wheel drive might work now as a stocker? AAFS?
MYRONARL1119 is offline   Reply With Quote
