Old 05-16-2010, 10:53 AM   #1
Redlight
Default 30x9 radial on a 12" rim?
Any problems putting a 30x9 radial on a 12" rim?
The tires have 5 passes on them so I would like to use them if possible.
I know the "rule of thumb" is + or - 1 inch of the tread width but I see some guys really stretching thier tires.
On the present chassis they are on a 10" rim but the offset for the new chassis needs to be different and have a set of 12" that will fit.
They would be screwed and glued as needed.
Will it work?
Redlight is offline   Reply With Quote
Old 05-16-2010, 11:04 AM   #2
treessavoy
Liked 4 Times in 4 Posts
Default Re: 30x9 radial on a 12" rim?
When I bought my Hoosier's the factory guys said to use an 8 to 10 inch wheel, no screws or glue. They did tell me to use rough sandpaper to roughen the areas around the bead to help seal.
I would call the tire makers before putting them on 12" rims.
JimR
Jim Rountree
Old 05-16-2010, 11:16 AM   #3
Steve Williams
Don't do it.
Steve Williams is offline   Reply With Quote
Old 05-16-2010, 11:29 AM   #4
Joe Martens
Joe Martens's Avatar
Liked 198 Times in 71 Posts
Thumbs down Re: 30x9 radial on a 12" rim?
I wouldn't do it.
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 05-16-2010, 12:01 PM   #5
Bob Bender
Bob Bender's Avatar
Liked 462 Times in 92 Posts
10 is about all you go............
Bob Bender 144 O/SA
Old 05-16-2010, 02:14 PM   #6
Rory McNeil
Even if you did put the 9" slicks on a 12" rim, I`d bet getting the beads to seat against the rim flanges should be good for a few hours of "entertainment", assuming a tubeless installation.
NHRA 6390 STK
M/S 85 Mustang
