Old 03-25-2010, 02:33 PM   #1
FED 387
Liked 336 Times in 183 Posts
Question intake manifold epoxy
Looking for a source for the epoxy that is used to fill in the voids grinding areas around the ports and such on aluminum intake manifolds.The stuff I have seen has been either beige/gray or lite green...Anyone know of a brand name or a supplier--thanx comp 387
Old 03-25-2010, 03:00 PM   #2
XSTOCKER
XSTOCKER's Avatar
Liked 8 Times in 3 Posts
Default Re: intake manifold epoxy
Goodson Tool porting epoxy
XSTOCKER is offline   Reply With Quote
Old 03-25-2010, 03:15 PM   #3
SSDiv6
Use either Belzona #1111. It is great when using oxygenated fuels.
http://www.belzona.com/prod1k.aspx
or
POR Patch
http://www.por15.com/PORPATCH/productinfo/PPW/
Old 03-25-2010, 09:54 PM   #4
FED 387
Thanx for the info will check into it this weekend--Comp 387
Old 03-26-2010, 09:23 AM   #5
SSDiv6
Originally Posted by Al Kuehl View Post
The green stuff is called Kop Coat splash zone compound . I got mine from Reher Morrision . It was a long time ago but check with them .
Al
I used Splah Zone in the past. I do not know if they have changed their formulation, however, when used with oxygenated fuels and other chemicals, it tends to break down.
Old 03-26-2010, 09:42 AM   #6
FED 387
for the amount I need Splash Zone would be cost prohibitive!!!!! That stuff is about $80 per small container. Will look into trying maybe JB Weld or Devcon too---thanx for all the ideas tho I appreciate the input---By the way this is going into an ALUMINUM SHEET METAL INTAKE MANIFOLLD not a cast manifold---do not know if that makes any difference. But keep those ideas coming will look into all of them---thanx Comp387
