Liked 203 Times in 80 Posts
Has anyone out there used this product? Does it seal small water leaks as the product description claims?
Mike Fuller 396 STK 3961 SS |
Liked 1,922 Times in 432 Posts
Yes, it does. I usually follow it with sodium silicate, found at the local drug store.
Alan Roehrich 212A G/S |
Thanks Alan.
in the old days of cast iron headed modified production cars,they bought stock in ceramic seal and usually used it every time the raced.engine builders always said if it didn't leak a little it wasn't going to be fast.
Liked 1,983 Times in 597 Posts
Mike,
If you have a crack or hole in the head you wll not have very good luck with any type of block sealer. I have tried them all. Sometimes you can get a temp fix from it. In my experience I have always had to find the cause of the water leak and weld or epoxy the problem. good luck
Mike Pearson 2485 SS |
Liked 783 Times in 195 Posts
This is the best product I have found for pesky water leaks in heavily ported heads: http://www.steelseal.com Pricey, but works.
Liked 60 Times in 12 Posts
There is also a Goodson product we used on my brothers car a few yrs ago. It worked real well. Its a liquid, and I dont think he's had any more issues with it.
2894 STK |
