Liked 5 Times in 3 Posts
Hey guys how or what do you drill the (i guess their steel) rocker arm fulcums with? My car has 3/8 studs & factory is 5/16....A regular bit just polishes it!!!!! HELP!!!!!
Liked 335 Times in 182 Posts
probably hafta use Titanium nitride coated OR Carbide bit--run it at low speed in a drill press and flood the drill tip with coolant---water-oil --cutting flluid
xxxxxxxxxxx
Last edited by GLEN DEMENGE; 09-09-2009 at 08:48 AM. Reason: i put in the wrong phone numer |
I broke 1 @ Columbus Div race... I went & found an Alum. 1 from Judi Bureski's husband & we (dad & i ) drilled it out in the trailer... All the others I have are the steel ones & rockauto.com has them for $5.40 a pair so I got 3 pair just 2 be safe. I don't like having the steel ones on all cyl but one...mine is set up as adjustable with 3/8 studs & sb chevy push rods... I guess spinning one of these 307 6800 in the traps is a bit much?
Greg
I had to use a reamer to take mine out to 3/8.Just use lots of coolant when reaming them out.
Alan Warman STK 4107 |
Guest
Posts: n/a
Greg,
Set them up in a vertical mill and use a carbide end mill. The end mill is a bit expensive. But it will tear thru those rockers like they are butter. ![]() Chris |
Liked 719 Times in 220 Posts
Would an American Motors rocker arm bridge work here? I had one apart once( a 304 powered Jeep) and they looked real close. I don't remember the brand name part we used on the engine rebuild for the Jeep, or whether it was aluminum or hard steel.
Thanks Guys! Hope to have it flying for the Northern Sports Nationals!
Liked 888 Times in 239 Posts
Olds and AMC pivets will interchange. ......I use an end mill to take them out to .375"
[and LOTS of coolant]. ......Tom
