Old 03-09-2009, 09:52 AM   #1
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Default Stocker Flat Tappet Oil....
What oil are you guys using for "dial-in" every day racing? I want to make sure to protect the camshaft from premature wear and any recommendations are appreciated. I've heard some oils dont pump the lifters up very well. Has anyone found this to be true?
Thanks for the info.....
Wade
Old 03-09-2009, 04:10 PM   #2
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Default Re: Stocker Flat Tappet Oil....
What your looking for is oil with the highest zinc content, Valvoline and Joe Gibbs are two I am sure there are more.
Bob Pagano A/SA
Old 03-09-2009, 04:17 PM   #3
Glenn Briglio
Glenn Briglio's Avatar
Liked 970 Times in 308 Posts
Joe Gibbs oil ssems to work well.
Old 03-09-2009, 06:47 PM   #4
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
My brother-In-Law uses this on every motor he builds. He has been seeing alot of bearing problems due to lack of Zinc as well.
http://www.lucasoil.com/products/dis...%20Zinc%20Plus
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 03-09-2009, 08:29 PM   #5
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Stocker Flat Tappet Oil....
Amsoil has several high zinc content oils. These are the ones I'm sure of:
http://www.amsoil.com/adslicks/ad995.pdf
http://www.amsoil.com/storefront/rd30.aspx
http://www.amsoil.com/storefront/rd20.aspx
http://www.amsoil.com/storefront/rd50.aspx
http://www.amsoil.com/storefront/hdd.aspx
Amsoil source and info link:
www.thelubepage.com
LOCOMOTION Racing
Old 03-09-2009, 08:33 PM   #6
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Shell Rotella T seems to work well for me in all engines, and very cost effective too
Old 03-11-2009, 05:24 PM   #7
455
Is anyone using Lucas Oil Products - "Engine Break-In Oil Additive" w/TB Zinc-Plus. How do you like it? Plan to use it in next oil change. Lucas says key benefits are:
Excellent for flat tappet camshafts during break-in or as an additive to any motor oil to prevent premature wear.
Exclusive blend of extreme pressure additives.
Add one bottle with every oil change to increase the zinc content of your motor oil.
Designed for race applications requiring additional extreme pressure additives.
Purchased mine at Advanced Auto.
455 is offline   Reply With Quote
Old 03-11-2009, 06:37 PM   #8
Bob Pagano
Bob Pagano's Avatar
njk53......yes it has, check before you buy any new stock.
Bob Pagano A/SA
Old 03-12-2009, 10:30 AM   #9
Run to Rund
Liked 54 Times in 27 Posts
The new diesel oil, spec SJ, came out along with the Jan 2007 introduction of particulate traps for diesel pickups. You want to find the older spec oil, CI4+, that does not meet SJ. the oil companies get away with saying the new stuff is backwards compatible and meets CI4+ spec, but the new stuff has different additives and a major reduction in what we want to protect flat tappets. Most retailers don't have the old stuff anymore, but Chevron distributors may carry the old stuff in 5 gallon buckets.
Old 03-12-2009, 02:50 PM   #10
njk53
Thanks for the info Bob P. Does anyone know if the petroleum based racing oils have as much zinc in them as the oils from the pre-government intervention days or do they contain reduced amouts of zinc?
Nelson Kowal
Stock 345
