What adjustments are you guys using on these shocks?
How many turns from the softest setting for the front and rear? |
Liked 314 Times in 177 Posts
Liked 1,026 Times in 281 Posts
I run the Spa1 rears on my Maverick, and I am an 1/8 of a turn off full tight with the Caltrak. When I ran the fronts. I was full loose.
Duane Hoven 1342 SS/GT |
Liked 226 Times in 137 Posts
Is SPA1 Koni Shock?
Liked 12 Times in 6 Posts
I am using single adjustable on front,1 sweep from full loose and double adjust on back, rebound 1 sweep from full tight, compression 4-5 clicks from full loose.
Liked 358 Times in 83 Posts
I have never gone wrong following Pustelny's advice: Start both fronts and rears in the middle of the range and tune from there according to what the 60-foot times tell you. You'll usually be fairly close on the back (starting in the middle) and you'll probably end up loosening the fronts a bit. In my humble opinion, there is no setting that works for all (or even most) cars. Your car wants its own setup.
#7 | |
Liked 923 Times in 262 Posts
If you get to dead tight, or one notch from dead tight, and the car wants more, it may be time to step up on the shock or shock valving. I want to run the shock somewhere in the middle, so I have room to adjust either way, and still have it as tight as I want. SPA1 is an old set up. Things have changed. I've taken SPA1 dampers off, replaced them with custom stuff, or an AFCO Big Gun shock, and made for a very different car. Front and rear. |
