Old 04-22-2021, 09:07 PM   #1
ImBack
Liked 5 Times in 4 Posts
Default Reverse pattern shifter
I was wondering what everyone was using for a turbo 400 reverse pattern hands-free shifter.Did some searching but was curious with new options out. Its a S10 bracket racer ,currently has a Shiftnoid on a Prostick thats hit and miss working.
ImBack is offline   Reply With Quote
Old 04-22-2021, 10:02 PM   #2
e vassar
Liked 281 Times in 110 Posts
Default Re: Reverse pattern shifter
Would probably go with Turbo Action
Old 04-23-2021, 12:35 PM   #3
mschafer
Liked 13 Times in 9 Posts
I run a reverse pattern 400 with a quarter stick and Shifnoid setup. had a problem with 2-3 shift until I figured out the pressure on the rooster comb was to high, relieved some of the tension by adding a couple flat washers between valve body and detent roller spring assembly as solenoid couldn't overcome down pressure.
mschafer is offline   Reply With Quote
Old 04-24-2021, 10:03 PM   #4
Eman
Liked 133 Times in 76 Posts
I had a Pro-Stick with the Shifnoid setup and struggled with it. It was shifting 1st to 3rd at times. I changed over to a Pro Ratchet with the Shifnoid setup and it worked flawlessly.
Old 04-26-2021, 12:21 PM   #5
Ken MacNicol
Ken MacNicol's Avatar
Liked 26 Times in 12 Posts
Turbo Action
Ken MacNicol is offline   Reply With Quote
Old 04-26-2021, 01:02 PM   #6
Wayne Scraba
Liked 196 Times in 49 Posts
Smile Re: Reverse pattern shifter
One of the nicest is a Precision Performance Shifter.....or an M&M Transmission shifter....
Just saying...
Wayne
Wayne Scraba is offline   Reply With Quote
Old 04-29-2021, 07:58 PM   #7
ImBack
Thanks for the help guys! I almost forgot I posted this haven't got around to racing yet this year. Lots of good suggestions
Old 04-30-2021, 10:50 AM   #8
Dano
Dano's Avatar
Liked 52 Times in 32 Posts
M&M with air shift.....pricey but worth it. You'll spend about as much for the PPP after all upgrades.
SC 707Y
Dano is offline   Reply With Quote
Old 04-30-2021, 12:03 PM   #9
jmcarter
jmcarter's Avatar
Liked 3,252 Times in 989 Posts
While my first choice would be Turbo Action I’ve been happy with the PPP that came in my car and Brad (think it’s just him and his Dad that operate Precision) was very helpful in sorting out the air shifting issue I had initially. My issue with the M&M is that it looks like a borderline patent infringement on the PPP.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 04-30-2021, 11:30 PM   #10
ImBack
For some reason I was thinking you had to move the shifter over then it went ahead and shifted into third on its own.
