Liked 3 Times in 2 Posts
I have the chance to buy a 1989 Camaro 5.0L TBI with an auto. Looks like Its a natural O/SA car. Its a street car with no title and missing some interior parts, but I can buy it cheap.. Can this combo be competitive?
Liked 976 Times in 311 Posts
The cam and heads aren't the best. Better combo is the 1990 5.0 TPI rated at 241.Better heads and camshaft and intake manifold.
1989 Camaro Iroc-Z I/SA B&B Auto Machine Shop. Last edited by Glenn Briglio; 12-23-2020 at 02:51 PM. |
I almost built one of these. It's so bad on paper that it's the kind of thing that I would do. Small cam (which doesn't seem to matter, lots of small cam 305s going fast),weird intake runner and not-so-good intake manifold. It makes tons of torque in a street car. I think that Tom Reese ran this combo for a while but switched to PFI combo.
I wonder if the 6 cylinder would be better, or maybe even an earlier year with a carb instead of the TBI? PFI might be better, but harder to find this cheap..Guy only wants 600 bucks for a complete car.
#5 | |
For $600, I'd be buying the car anyway. Check the lower cowl and the rear frame and wheelwells for rust.
Liked 17 Times in 3 Posts
I’m attempting to complete a 6 cylinder project, but I’m concerned that I can’t get enough HP out of the cubic inches available. Basically I don’t know that I can get to 1.3 hp/cubic inch to mathematically get to the index. I would think it would be much easier to run a 302 V8 which is factored the same as my V6. They already have 30% more cubic inches, no mind the additional torque.. Either way I guess I’ll still be able to bracket race it on Saturday night..
Liked 269 Times in 99 Posts
The hurtle with TBI is injector size. Once you get to the point of needing more fuel there is nothing larger available. Am sure the TB will flow plenty of air fuel demand needs to be overcome.
That thing will move a full sized Caprice with no problem.
I'm sure it will run under in P/SA. You have to maximize torque and then set the car up for it. (Small tri-y headers, etc.) You might want to invest in a dyno test so you can figure out the converter and gearing...unless you're really good at this ;-) Go for it...
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 12-23-2020 at 09:04 PM. |
So question, if its a natural O/SA car and you say it should run under in P.. is it safe to assume it will also run under in its natural class and its "Light" class?
#10 | |
O to P , a full pound break, thus 210 pounds for three tenths.
