Go Back   CLASS RACER FORUM > Class Racer Forums > Factory Stock and Super Stock
Old 07-12-2016, 01:06 PM   #1
Hotroddragpak
Default Fuel Sample Valve location
I'm wondering if I can run my fuel sample valve out the front of the car coming out of the grille on my Drag Pak? I saw a stocker drag Pak plumbed like this. The 2010 drag Pak has a dzus fastened hood and is a pain to remove. Any help on this matter would be greatly appreciated.
Hotroddragpak is offline   Reply With Quote
Old 07-12-2016, 01:31 PM   #2
john corcoran jr
Liked 16 Times in 10 Posts
Default Re: Fuel Sample Valve location
I know what you mean about the hood being a pain. I put mine in the fuel filler door pocket. I was told that as long as it is on the outlet side of the pump it was good.
john corcoran jr is offline   Reply With Quote
Old 07-13-2016, 07:52 AM   #3
Dave Gantz
Liked 251 Times in 125 Posts
Only thing is, if I'm a tech guy, how do I know where your sample valve's source is, if the hood isn't open?
Old 07-13-2016, 08:06 AM   #4
Bobby DiDomenico
Liked 101 Times in 52 Posts
That is why I thought it was under the hood so they could verify the plumbing.
If in the grill location is the valve actually "outside" the car structure in the event of a wreck?
Old 07-13-2016, 11:38 PM   #5
Hotroddragpak
That's what I was thinking, bit apparently it's legal for these cars. I'm just going to mount mine on the pressure regulator and remove all doubt from where the fuel came from. Just thought about mounting where it was easy to get to. The fuel door idea sounds great. They could see where the fuel is coming from being that close to the fuel source. But that's another project for later...
Old 07-24-2016, 07:28 PM   #6
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Fuel Sample Valve location
Great point! Jim
Old 07-24-2016, 07:31 PM   #7
Jim Wahl
Jim Wahl's Avatar
Talking Re: Fuel Sample Valve location
Never assume it's legal just because you saw it like that on somebody else's car!! Find out from your local neighborly tech guy! Jim
