Liked 53 Times in 16 Posts
Regarding a 1986 305 Camaro.
1) Are roll bars allowed in Pure Stock? No mention in rule book not allowed? 2) Aftermarket Shifter allowed? 3) Mini spool in 7.5 rear? Thanks Will Lamprecht |
#2 | |
Liked 184 Times in 113 Posts
And mandatory if quicker that 11.49sec or Convertible. Aftermarket Shifter YES. MiniSpool....I do not know..but should be ok! They are a bit stronger more reliable than Posi's. D |
Thanks Dan, I knew you would be on this ASAP !!
Have this 1986 Camaro with a great running 305 4 bl , originally thought about 4 cylinder W/SA car (have lots of 151 CI parts for that) but would be cheaper right now to build a PS Add a higher stall converter for the 700R4 , 4:57 gears w/spool (have) , headers, roll bar (just in case want to make a traditional stocker too one day) fix body ect. I guess it would fall into E/PS with a 13.40 index. I think very possible with those gears. Even though here in Northeast not much IHRA, car could run ASRA Stock/Super stock combo races, then remove mufflers to bracket race. Also drive on street locally ( would trailer to track) Will |
Liked 319 Times in 68 Posts
Will, talk to Lloyd Rielly former owner of RCE Machine in New Milford.He still has his E/PS record holder. He's a great guy and a wealth of knowledge. Call me at The Toy Box and I'll hook you up.
Lee Valentine 1661 STK |
#5 | |
Right now watching the snow come down. Otherwise yeah should run well under the E/PS index. Btw if you are using stock exhaust manifolds you can run without mufflers. Mike Taylor has a similar combo in a Malibu. Ping Mike Baker confirming the class. D Last edited by Dan Fahey; 01-23-2016 at 12:19 PM. |
Dan I have a photo of his car on my toolbox at work, I'll get it to you.
Will,
Contact CJ McDonald.he has a complete pure Stock rear end for that car. Chip Johnson |
Liked 313 Times in 106 Posts
Can run roll bar/cage,but have to keep rear seat though,had mine out and had to reinstall it.
if it is flat top 305 have nice set of venolia pistons .030 they are older so they would be heavy enough to be legal $375.00 for them Mike Taylor 3601 |
