Old 11-06-2015, 08:24 PM   #1
Tom Meyer
Liked 354 Times in 120 Posts
Default Carb ID and app
Need a carb id and what it would have come on. 7028210 Q Jet, was on a 69 chevelle 325 / 396 auto nov 68 production date, is this the correct carb for this app? Tom
Tom Meyer 5240 SS Stock ???
Old 11-06-2015, 08:54 PM   #2
dondon
Liked 10 Times in 5 Posts
Default Re: Carb ID and app
it's for a 68 385hp 727 auto
dondon is offline   Reply With Quote
Old 11-08-2015, 12:17 PM   #3
MAURICE BLENDHEIM
Liked 286 Times in 88 Posts
Tom…1968 Camaro 396-325HP with Automatic. MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 11-08-2015, 12:29 PM   #4
Mike Jones
Liked 684 Times in 289 Posts
here is a link:
http://quadrajetparts.com/decode-you...retor-t-5.html
another site I went to agreed with this
looks like 68, non California, automatic trans.
didn't see engine / model specific info.
Good Luck
Mike A114
P/SA
Old 11-08-2015, 06:52 PM   #5
dondon
a 1968 396/325 hp is a 7028218. you can check NHRA web site under engine blueprint specs. they have the correct numbers
Old 11-12-2015, 01:38 AM   #6
GTX JOHN
Does the number matter to NHRA as long as internal dimensions are correct?
John Irving
741 Stock
741 Super Stock
Old 11-12-2015, 04:04 AM   #7
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: Carb ID and app
No. Short answer. Jim
Old 11-12-2015, 08:56 AM   #8
Tom Meyer
This is for a resto, needs to be the right numbers match that I think now is 702900. Did you know that the min spec has a 15ths grace measurement. Tom
Old 11-15-2015, 09:52 AM   #9
Mike Jones
Tom,
Should it be 7 digits?
Mike A114
P/SA
Old 11-23-2015, 01:08 AM   #10
Greenlight
Liked 81 Times in 23 Posts
Rochester Carb. Stamping Codes
First part of stamping number:
702 - Late 1960's
703 - Late 1960's with Air Injector Reactor (some exceptions exist)
704 - 1970-1975
1705 - 1976-1979
1708 - 1980's
Then Model Year (i.e., 7=1967, 9 = 1969, 0=1970, etc.)
Then Carb. Type
0 - Monojet, Federal Emissions
1 - Two Jet, Federal Emissions
2 - Quadrajet, Federal Emissions
3 - Monojet, California Emissions
4 - Two Jet, California Emissions
5 - Quadrajet, California Emissions
6 - VariJet, Federal Emissions (2 barrel)
Then Division of GM
0, 1, and 2 were all used by Chevrolet (2 used on Cadillac also).
3 - Cadillac
4 - Buick
5 - Olds
6,7 - Pontiac
Then transmission type
0,2,4,6,8 Automatic Transmission (some exceptions exist)
1,3,5,7,9 Manual Transmission (some exceptions exist)
On some carburetors there is a production code (usually a two letter code) stamped below the numerical ID code.
On some carburetors there is a manufacturing date code below the production code.
Example: 2277 would indicate the 227th day of 1967 or 1977, depending on the year specified in the ID code.
Greenlight is offline   Reply With Quote
