Old 10-19-2015, 07:11 PM   #1
rseibenick
Liked 20 Times in 7 Posts
Default Hydraulic throw out bearing
Any one using a hydraulic throw out bearing with their soft lock clutch set up? Have limited space in my bell housing .
rseibenick is offline   Reply With Quote
Old 10-19-2015, 08:44 PM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 274 Times in 76 Posts
Default Re: Hydraulic throw out bearing
I had one for a short amount of time before converting my car to a stocker. It was not ideal with a softlock clutch. The adjustability for airgap is not consistent. Adjusting for reaction times is a compromise between affecting the TOB air gap and clutch air gap. I would not recommend hydraulic unless its a daily driver. Unless it was a factory option this would not be legal in stock.
What application and bellhousing? There are ways around the problem that you have, as many of us have had the same issue to solve. Do you have an adjustable pivot? If not, buy one or make one. The clutch fork may have to be modified to solve some of the issue as well.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 10-19-2015, 09:46 PM   #3
rseibenick
Sean , you have a PM.
