Old 06-18-2015, 04:18 PM   #1
BLIND MULE
BLIND MULE's Avatar
Default 64 Falcon Wagon front suspension?
Got a little 2 door been racing for 10 years ladder bar rear with stock front end components! The car works pretty good but think front needs some help!It has stock type shocks from the Zone will the Calvert 90/10 be helpful also read about the roller perches are they hype or do the perches really help? Any other tips that may be helpful it's also a 6 Cyl front end with the 4 lug drrum brakes I have a complete V8 5 lug front end I can use? Brakes are ok what about a disc swap read also about the Scarbird kits or just stay with the drums?
Thanks!
BLIND MULE is offline   Reply With Quote
Old 06-18-2015, 04:25 PM   #2
FED 387
Liked 336 Times in 183 Posts
Default Re: 64 Falcon Wagon front suspension?
blind mule u still want that helmet??? by the way I know nothing about Falcons--FED 387
Old 06-18-2015, 09:36 PM   #3
Mile High
Mine has basically stock parts. The upper control arm have been lowered an inch (the old Shelby trick). 90/10 shocks and Moroso springs. The springs I cut 3 loops to get the nose down. After a couple of years added 1' rubber spacers to raise it a little. The rubber is getting beat out of the spring perches so the roller bearing ones would be a good upgrade. Poly bushings for the strut rods and a thick washers. Mine tries to pull the nut through the thinner washers. Willwood disc brakes up front. My Sprint will run 10.50's - .60's with low 1.40's 60' numbers footbraking with a 2 step.
Jeff
Street legal 64 Falcon Sprint with 410W living in Texas.
Stock - Super Stock fan
Mile High is offline   Reply With Quote
Old 06-27-2015, 01:32 PM   #4
nhramnl
Liked 358 Times in 83 Posts
It's basically identical to '64 Mustang suspension, right? If so, call Pustelny at MPR. He has setup for them.
Old 06-28-2015, 05:30 PM   #5
Mile High
Without the Falcon there would not have been a Mustang.
Jeff
Old 06-29-2015, 11:24 AM   #6
Rusty Gillis
Rusty Gillis's Avatar
Liked 87 Times in 19 Posts
I use Opentracker front suspension
http://opentrackerracing.com/product...s/drag-racing/
Rusty Gillis
Former NHRA SS/FA and SS/GA record holder
Rusty Gillis is offline   Reply With Quote
Old 06-30-2015, 02:47 PM   #7
Capri
Liked 27 Times in 14 Posts
I have everything you would want on the shelf, in stock, no waiting.
Capri is offline   Reply With Quote
Old 06-30-2015, 06:42 PM   #8
1965
The big difference in falcon vs mustang is drag link for falcon is 1.5 inches shorter then the mustang everything else will interchange,,, I have a 65 mustang fastback and a 65 falcon 2 dr delivery
I am using stock on mustang other than granada brake set up with lowered lower control arm to cure bump steer
1965 is offline   Reply With Quote
