Old 10-06-2014, 10:26 AM   #1
Dave1695
Liked 15 Times in 11 Posts
Default Upper ball joint length
Have heard that using an upper ball joint with longer shank on a first generation Camaro, will reduce/eliminate the camber change during wheel stand. Anyone have any experience in that area? What is the best shank length to choose? Going to freshen front end this winter with AFCO or other quality pieces. Thanks in advance for your feedback!
Dave1695 is offline   Reply With Quote
Old 10-06-2014, 01:16 PM   #2
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default Re: Upper ball joint length
I am going this route this winter also.
http://classracer.com/classforum/showthread.php?t=18613
Old 10-06-2014, 05:49 PM   #3
tj310
Several discussions recently ---Trevor http://classracer.com/classforum/sho...man+ball+joint
Old 10-06-2014, 05:53 PM   #4
Kegracing
Dave,
Search some of my recent threads about front end issues.
I just ordered the 1/2" longer ProForged top joints. Have not installed yet, but they look and feel good.
Finding a longer and low friction top ball for 1st gen is a problem.
Good luck,
Ken
Stock 412
Kegracing is offline   Reply With Quote
Old 10-06-2014, 08:15 PM   #5
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: Upper ball joint length
I have an ancient set of Stahl/Moroso upper ball joints that are 1/2 longer than stock, and they do correct the problem you mentioned. I more recently bought some of them from Howe Performance. They are a very nice unit and work very well too. Kind of pricey though.
Jim Cimarolli is offline   Reply With Quote
Old 10-07-2014, 08:52 AM   #6
Dave1695
Thank You for all the feed back gentlemen, I really appreciate the help!
