My name is Mike Keener I have not been on here much in years. I ran a 82 Mustang in p/sa about 5 years ago my son is wanting to get the car out race. Has the HP changed any since then, it would only go 5 under then. When NHRA took off the 3 hds. we parked it, because at Bristol it would not index. thanks
Liked 5,147 Times in 1,964 Posts
It's 157 as of last August. I don't know what it was before then.
It makes R/SA now .It ought to run the index now. There was a similar Capri in Div. 6 last week that ran about 9 under Might I ask..What type of converter is in it?
It was 170 when we ran, so that would help a lot. The converter is a PTC stall is about 4300
Sounds about right then. Kenny knows that stuff pretty well.
How about the cam and gear ratio? PM me if you want to on that.
Liked 1,110 Times in 304 Posts
I was always under the impression that the 82 GT "HO" 2 barrel 302 engine was a stick only combination. Like the 83-85 4 barrel HO Mustangs & Capris were. You could get a 5.0 with a AOD automatic , at least in 84 & 85, but they all came with a CFI throttle body EFI.
#6 | |
#7 | |
Liked 2 Times in 2 Posts
Hay Mike good to hear from you Did Dave get you that catalog you wanted? We changed it over to a 302 a few years ago,that 255 sucked the cyl walls would not stay round.
