Old 09-03-2013, 09:34 PM   #1
Joe Toller
Liked 4 Times in 4 Posts
Default How often do you swap slicks?
How often do you guys swap out slicks for new ones? Every season, after so many runs, or ???. Is there really a huge advantage, as in, do they fall off in performace a large amount? I am guessing the lower HP cars do it less frequently?
I don't think I will have an issue, but I am very curious.
Old 09-03-2013, 09:48 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: How often do you swap slicks?
Some brands go away faster. In my limited experience Goodyears go away sooner. 30 to 40 passes. Hoosiers & MTs have worked until cord was showing.
Do you turn yours around (swap sides) every few passes? They seem to work better longer doing that.
Ed Wright 4156 SS/JA
Old 09-03-2013, 09:49 PM   #3
J.R. Haddad
Liked 1,464 Times in 307 Posts
When everything else is right, and the 60 ft. and E.T. start to fall off, and your
lights start to get erratic, it's probably time for a new pair.
J.R. Haddad is offline   Reply With Quote
Old 09-03-2013, 09:54 PM   #4
Dion Hildebrandt
Dion Hildebrandt's Avatar
my 3500 pound 300/286 horse 70 chevelle will get no more than 40 runs on a set of M/T radials, I don't even bother doing anything but check pressures anymore. Ed is right they work right up to the cords showing....done that a time or two....
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 09-04-2013, 08:07 AM   #5
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
too many variables....,power, weight, tire manufacturer, tire size, tire type, air pressure, burnout, yada, yada, yada, to state a definitive number.
Old 09-04-2013, 11:21 AM   #6
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
I use the Hoosier DOT's for Pure Stock and get as many as 200 runs out of them.
Most tracks are well prepared and need little buffing.
Get them spinning see smoke and roll out..
The new tires seem to be a bit more rugged, last longer and have good consistent bite.
However my car is heavy and may not be as sensitive to the vulcanization from repeated heat during burnout.
D
Old 09-12-2013, 06:48 AM   #7
Liked 10,687 Times in 2,225 Posts
103 and counting Goodyear 4457, swap them side to side every four to six runs. I use a light burn out in 2nd gear and go race. 3600lbs. car with almost 600 ft./lbs. of torque.
Old 09-12-2013, 07:59 AM   #8
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Larry,
How long does it take for you to make 103 runs?
I haven't made that many in the last two years.Too many first round losses, I guess.Congrats on your latest win.
Old 09-12-2013, 08:07 PM   #9
Ed Wright
Ed Wright's Avatar
Larry, Kenny Faulk is who told me the Goodyears tend go away sooner on Amy's Stocker. Probably 5 years ago. May not still be the case.
I have one set. Hook as well as the MTs on good tracks. Not as well for me on marginal tracks. Only about 15 passes. They slow my car down 4 to 5 Hundredths.
(5lbs each heavier, I assume that 10lbs more rotating weight on a 31" circle is why) therefore I have not run them long enough to actually know when they would go away.
Sure would like to sell them.
Since I don't actually know from experience, I should have kept quiet. Sorry.
Old 09-12-2013, 08:20 PM   #10
Joe Toller
I am looking for a pair Ed...
