Hey guys,
I found this recommened combo on another website. What type of driveline/fuel system would be common with this combo in a 3800 lbs door car? Would a "stock suspension" work or is this territory for back half cars? I have the bottom end parts to replicate this, but the heads would be tricky. I think a set of cast iron rectangular port would work better since my porting skills aren't a high level. I know the valvesprings aren't cheap as well as the other valvetrain.. 700hp 468 bbc Yes you can build this engine to that power level. What you end up with is a Super Stock Supergas motor with very high compression 14:1+ full max ported big valves 781 heads, forged domed pistons (JE, Ross) Crane full race roller camshaft 280in-290ex @.050" .750" to .800"++ lift 110-112LSA Full race high rpm valvetrain w triple springs may have over 1000# open spring pressure at full lift. stud girdle and rev kit. Tunnel Ram and two 750's/850's or a full race single plane (Dart) and Holley Dominator 1350cfm carb. Big tube 2-1/4 Hooker , Hedman Huster race headers A GM LS-6 or LS7 forged crank is best. It requires 114octane race gas or methanol. regular maintenance items will be bearings, valve springs roller lifters and connecting rods. Needs a custom 6000+ rpm race converter and lots of gear and rpm. Precision machineing and preparation is required, The block, heads and forged rotating assembly need a full race work up. These are the basics of a 700+ HP 468 oval port head BBC. This is not a street motor.
http://www.youtube.com/watch?v=h2qQX4TDTVU |
A Super Stock engine, as applied to this forum, has rules which are mandated by either NHRA or IHRA. Briefly, a SS engine will have to match a year and body claimed and must include factory spec valve sizes, piston dome configuration and carburetor(s). You can have a replacement intake manifold but it must configure to factory (i.e., if it came with a single quadra-jet it must have a single carb intake manifold under a spec quadra-jet. If it came with 2 4bbl carbs it must have 2 4bbl carbs inline or off-set like factory installed). The race organization also specifies the volume of certain parts like intake / exhaust runners and combustion chambers. In a nutshell, that says what you are proposing is a Bracket or maybe Super Gas or Super Street type engine. But definitely not a traditional Super Stock engine.
Good luck and have fun.
Jeff Lee 7494 D/S '70 AMX |
Thanks Jeff,
I will try to find a Super Gas or Super Stree section, it's crazy how fast you guys go with Q-Jets ![]()
#4 | |
Liked 136 Times in 49 Posts
I have a old Car Craft mag from the '90's and there was a similar year Monte with the same kind of motor. He was doing some sort of class racing but it might have been a specialized catagory..Anyways, I figure a lot of convert&gear with this combo hooking up would be interesting as well..
Liked 404 Times in 158 Posts
HEY!!! That's Luskville! haven't raced there since 97.....ok, don't have anything to offer...just don't normally watch u tube and recognise the tracks...
All right, nothing to see here, move along... (and yes the car leaves nice) |
Yep, it is Luskville! It is close (it's only like 30 miles from my house)..
I found the article it is from Car Craft of January 1997 the classification appears to be SS/FA. The guys name is Bryan Broaddus (he is from Yorba Linda California). The car (1970 Monte) still has to cofirm to a certain things (iron heads, no combustion chamber mods, lower compression, 780 carb, but the cam can be huge 287-288@0.050) He uses (or used to article is 15 years old ) ladder bars, 6.0 gears, 5500 stall..It runs in the 10.30's...
