Old 07-14-2012, 05:17 PM   #1
slick5861
Liked 2 Times in 2 Posts
Default powerglide question
On a powerglide, which fluid outlet, top or bottom, would go into a filter\transcooler ? The filter has a in and out on it. Thanks
slick5861 is offline   Reply With Quote
Old 07-14-2012, 06:37 PM   #2
Denny Bloom
Default Re: powerglide question
Bottom out, top in
Denny
Denny Bloom is offline   Reply With Quote
Old 07-14-2012, 07:11 PM   #3
Bobby Zlatkin
Bobby Zlatkin's Avatar
But, can both be plugged?
I know this can't be done with a T350, as there must be a loop connecting the two ports to keep the path of fluid open.
However, I've aquired a race prepared powerglide and both ports are plugged. Is this OK?
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 07-14-2012, 07:31 PM   #4
Liked 5,147 Times in 1,964 Posts
Bob, both the PG and the T350 have a cooler bypass valve .It is there for extreme cold climates, where the fluid can't be forced through the radiator cooler without putting strain on the pump .
Remove the bypass ball and spring assy., plug the holes, and you will loop the fluid internally.
