Old 05-11-2012, 09:52 AM   #1
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Question STRANGE BRAKES?? dragging
My STRANGE BRAKES are dragging.(all 4)
What is the fix for this?
I have the large boar Strange Master Cylinder. a Willwood Prop. Valve.
I have checked the rod & peddle it has free play, I don't think it's the problem.??
I have read something about new O-RINGS??
Could someone please elaborate.
Thanks for your help!
Glen DeMenge
MEXJOE is offline   Reply With Quote
Old 05-11-2012, 10:06 AM   #2
Charlie Yannetti
Liked 192 Times in 83 Posts
Default Re: STRANGE BRAKES?? dragging
I had this problem with my Strange rear brakes.. the pads wore down to a point where the pistons would not return, causing them to drag.. the pads didn't look that bad, but I guess they were worn down just enough.. but looking under the car, you could see the pistons exposed way out of the caliper.. I have changed the O rings periodically, but changing the pads did the trick for me on this occassion..
Also, if you have recently changed the pads, make sure you have clearance to the rotor to begin with.. some are thicker than others..
Charlie Yannetti is offline   Reply With Quote
Old 05-11-2012, 07:56 PM   #3
sixty8
sixty8's Avatar
Here is another thread about this...
http://classracer.com/classforum/showthread.php?t=38980
I found the springs to be a solution.
sixty8 is offline   Reply With Quote
Old 05-12-2012, 12:46 AM   #4
mitch sowers
One more thing to check ! Make sure your rotor is centered in the caliper. If it is off center you might have a pad draging one side.
Check this with all pcs. bolted up...[ with out the pads in place]. Mine came with a shim pack [thin washers] to space the caliper housing in or out.
PUT LUG NUTS ON THE ROTOR HAT , TO MAKE SURE THATS SNUG IN PLACE ALSO. Hope this is some help !!!!
mitch sowers is offline   Reply With Quote
