Old 03-06-2012, 10:49 AM   #1
Rob Petrie E395
Liked 216 Times in 77 Posts
Default 30X9 better on a 8 or 10 inch rim
Would be for a 96 Firebird stocker. Not sure on radial or bias yet but I would say at some point I will have both so opinions on both ways would be great.
Thanks
Rob
Old 03-06-2012, 11:30 AM   #2
Run to Rund
Liked 54 Times in 27 Posts
Default Re: 30X9 better on a 8 or 10 inch rim
I asked a former D/S record holder and he said he didn't see any dfference. Most people seem to run 10" but if clearance is tight, remember that the section width will be about .3" per side narrower with the 8" wheel (or .6 to .8" overall width difference per tire).
Old 03-06-2012, 11:36 AM   #3
Jeff Lee
Jeff Lee's Avatar
I'm splitting the difference, just ordered a pair of 9" wide Bogarts yesterday.
Jeff Lee 7494 D/S '70 AMX
Old 03-06-2012, 11:56 AM   #4
Dwight Southerland
Dwight Southerland's Avatar
Liked 772 Times in 192 Posts
Does that mean you are a compromiser? Somehow that does not compute . . .
Old 03-06-2012, 12:38 PM   #5
Jeff Lee
Jeff Lee's Avatar
OK...I really think the tread and rim should be in zen with one another, equally disbursing the load. I think most choose 8" or 10" because a 9" is not commonly available.
Old 03-06-2012, 12:53 PM   #6
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: 30X9 better on a 8 or 10 inch rim
I never actually compared the two sizes, but I've always been under the impression that with a wider rim, you can run more air pressure, which stabilizes the sidewalls more, while still achieving a full-width footprint. I've always used 10" rims with my 9" Hoosier slicks.
Old 03-07-2012, 10:17 AM   #7
terry1
Liked 24 Times in 13 Posts
Wink Re: 30X9 better on a 8 or 10 inch rim
I use 8.5 " rims on my 30 X 9 's stick combo(Convo Pros).How's that for a compromise
terry1 is offline   Reply With Quote
Old 03-08-2012, 03:13 PM   #8
Rod Greene
Liked 242 Times in 81 Posts
It depends on the tire company. In the past I have run just about every brand of tire. Most worked better on 10inch wheels. The M&H and Toyo's liked 8 inch. This is on a stick car with bias tires.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 03-08-2012, 03:38 PM   #9
treessavoy
Liked 4 Times in 4 Posts
Hoosier advised me to run 10" rims with their 9x30's.
JimR
Jim Rountree
Old 03-08-2012, 05:42 PM   #10
Jeff Lee
Jeff Lee's Avatar
With the offset I wanted and I wanted a welded pair of Bogart R/T's (hate all those little nuts and bolts!), I'm ending up with a 9 1/4" rim. How's that for being on the gnats ***?
Rod...any progress? Need you to get moving. I want to race!
