Liked 6 Times in 5 Posts
Just wondering if anyone is running the 340/275 (AVS) in Pure Stock? Some time ago I remember someone running a '71 Demon 340/275 (TQ) as a Pure Stocker, and would appreciate any info I can glean.
I may initially build my '69 Dart as a Pure Stocker to get my feet wet in our local Stock/Super Stock series, then work my way up ($$$$$) and build it as a traditional Stocker. |
I have a '70 340 Dart Swinger that I run in Pure Stock. I can help out as much as possible, though my experience is limited. I didn't run last year, and only once the year before. limited time and resources lately. I just went through it last year so I hope to run a little more this year. I barely run the index, but I built everything myself.
PM me and we can talk. Mike I run D/PS, have run under 3914 and 5914
Mike Coates TBD |
In pure stock, you must run manifolds and polyglas tires, no port work of any kind, 2 1/2 exhaust with H or X pipe
Tom cannon runs a 71 with that carb in pure stock |
1971ls6: I believe you're referring to the "Pure Stock Musclecar Drags" series in which you must run manifolds and bias tires.
Mark: IHRA has a Pure Stock class that NHRA doesn't. Our local series runs under IHRA rules which open things up to more participation from 'different' classes. You can't use a 'stocker cam' as a traditional stocker can. But I've read here that you should have a cam ground which will check within the specs but should work better than a dead stock grind. Can run headers with mufflers OR open manifolds. You can check out the rule book at http://www.ihra.com/. Thanks for the replies guys. Last edited by Todd Boyer; 02-05-2012 at 09:32 AM. Reason: added material |
#5 | |
Banned
Liked 235 Times in 110 Posts
Correct on all the above. You can run 9 inch slicks at 29.5 diameter. The cam MUST check on OEM duration and over lap like in the Jr. stock days of pre 1972. The valve springs must check on OEM open and close pressure specs also. Just pretend your racing back in 1971 Jr. stock days if your old enough to remember those days. Last edited by X-TECH MAN; 02-05-2012 at 09:07 PM. |
Liked 534 Times in 143 Posts
Is there a list of the current Pure Stock records?
#7 | |
Mike Carr, Tri-State S/SS Association President Looking for 2015 S/SS Race Sponsors Contact me if interested buffdaddy_1302@hotmail.com (724) 510-5912 |
#8 | |
Todd,
I have been running 1 3/4 headers on mine with flow master mufflers. I don't have a cross over pipe. My thought was run the larger pipes since the muffler was required and will create some back pressure. I haven't done any additional testing with smaller hearders or X pipe. Mike
Mike Coates TBD |
The worst part of this whole deal is that I just sold a set of Hooker 1 5/8" street & strip headers that I think may have worked with this combo. The main reason I'm wondering if the 1 3/4" will work is that I already have them, and will run them when I eventually build the car into a traditional stocker.
Like Mike, my thoughts were that I could get away with the larger pipes with the exhaust system creating at least some back pressure. Mark, I know you're the man for headers, so in all honesty, what kind of ET difference can I expect between the 1 5/8 and 1 3/4 pipes? For our local series, I'd be really happy to be -.2 or .3. I used to run my street/strip '69 Dart with a very mild 360, 904 with 3400 stall converter with 4.10s on 26" slicks. It went a best of 12.9 @ 105 (it was a street and strip car). The car had full exhaust including tailpipes and OLD Dynamax mufflers. |
