Old 02-04-2011, 11:42 AM   #1
rod
Liked 20 Times in 15 Posts
Default alignment?
i am hesitant to post this here, but you guys are smart, and hopefully someone will answer.
i just had my '67 Chevy truck front end done. the toe-in came out [computer print-out] as degrees. can some one tell me what .38 degrees [total] is in AMERICAN inches.
thanks so much
rod in AZ
rod is offline   Reply With Quote
Old 02-04-2011, 05:19 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
Default Re: alignment?
On our Bear machine .3 degrees is equal to 1/8".
Old 02-04-2011, 10:34 PM   #3
rod
thanks tom. i did some calculations and i figure .38 degrees is closer to 5/32". way to much, especially with brand new parts which don't need to be 'pushed' to take out the worm slop.
rod in AZ
Old 02-06-2011, 12:30 PM   #4
Stewart Way
Liked 70 Times in 22 Posts
I understand that .3 degrees would be from parallel on the tires, but when it is given in " as in 1/8" how far forward and behind from the centerline of the spindle is the 1/8" refering to. The farther forward the 1/8" is the fewer degrees it would be. Is there a standard?
Stewart Way 2424 SS
